- Joined
- 17 Aug 2010
- Messages
- 2,888
- Reaction score
- 506
- Country
I know - all I can do is report what happened!That's rather amazing. If water was creating an L-N path that was somehow carrying 36A+, it would seem very unlikely that 30mA would not get from L to E!As it happens everything here is RCD protected except a couple of indoor fridges/freezers (not the one in the garage). The RCD did not trip.
Yup - It was the worst storm we have ever had here. Storm start to trip 5 minutes. Almost unbelievable.I'm not sure that you're answering the question I asked - namely how long it was from when the water hit the freezer electrics to when the MCB tripped. You're surely not saying that the water level in the grage got high enough to recah the freezer's electrics within 5 minutes of the rain starting?I think I knew within seconds as the internet router is powered from the same circuit, and I was tracking the lightning strikes. Guaranteed to get an instant reaction in our house if we lose the circuit powering the internet. So less than 5 minutes to trip the MCB.
Once again - I don't know - all I can do is report what happened! When I have looked at the stuff behind a freezer - it doesn't looked that sealed. But I don't have any facts to report in that area.I'm not sure what you are suggesting here. IME, the compressors of fridges and freezers are invariably totally enclosed/sealed - so there's no way that external water can get near any moving parts. Are you perhaps suggesting that a short through water reduced the voltage supplied to the compressor to a low enough level that it could not turn, yet with a voltage still high enough that "tens of amps" could flow through the non-turning motor?Probably need to look for a way the freezer could take a large current when water covered the motor. Maybe the motor wouldn't turn.
As said the MCB would not close, until we unplugged the freezer. Then it closed immediately.Edit: one further thought - are you sure that it was the water, and not lightening, which caused the MCB to trip? (it's not uncommon here for both RCDs and MCBs to trip when there is nearby lightning - presumably due to interference with their electronics)
This is definitely an MCB - I installed it myself 7 years ago - everything MK for what it's worth.
