elkato ncs by all means i say ar is bit to far
To be fair when the fence was erected it was done with nothing but happy spirits! The previous owners (of both properties) got on famously, and they have been nothing but EXTREMELY supportive during this crisis.
You know what it's like; you don't intend for things to get sticky at any point. So yeah no challenges against them - they're LEGENDS.
ddm*
Namsag, the high level situtions can be seen even from a distance and it is very unlikely that an obstruction not apparent on inspection would impede the flue. This is a low level (boiler under worktop).
agreed thats why i would recommend a co detectorYes adlplumbing your probably right with NCS but there is clearly more potential danger than if the flue was also NCS but on the other side of the fence. I would still be giving strong advice to have it moved. If it was mine, i'd want to check regularly to make sure the neighbour was not storing his barbecue in front of it.
I've always understood,possibly incorrectly, that no flue should discharge closer than 600mm toward a neighbours boundary (now 2500mm for condensing boilers).
Where does your coal bunker fit in with the fence?
Perhaps you and the OP are neighbours as he has not said where he is !
