How did this sound - its just a heater in the tank ? Not sure what you would hear , but never listened closely
It's usually a humming sound, like air is circulating fast if that makes sense. I have attached photos of where this sound usually comes from.
Whats a HOT PRESS?
How long has it been left 'ON" for - our immersion takes a while to heat up a small tank, probably a couple of hours to get hot.
Not sure i understand that either
If an Immersion it just heats a tank of water - I suspect after 1/2hour it maybe warm not as cold as the cold tap.
Hot press is where we have our hot water tank and washed clothes we want to dry. Not sure what's the name for it outside Ireland.
Problem is after half an hour nothing was warm, the water, hot water tank and radiators were all still cold. With our old switch it only took half an hour at most to heat them all.
Was the timer set to run ALL night then , and no hot this morning ?
maybe best if its set to heating on "ON" with Neon ON and after a few hours, water should be at least warm, depending on Temp Setting on thermostat , if has one - and as posted maybe it needs a reset
It was on CLOCK and set to a time this morning set by the electrician at my request, but it never went on this morning.
We never used to leave our old switch ON for any more than an hour as we were warm enough after that, and didn't want to be spending too much on oil. Should I leave the switch to ON for a few hours?
