- Joined
- 22 Jan 2007
- Messages
- 23,438
- Reaction score
- 3,306
- Country
I think around these parts
Where's that Dickie, Bearsden or Milngavie????
I think that's nationally D.Where's that Dickie, Bearsden or Milngavie????
Looking at the skirting boards and door linings I'm guessing this is a Call home? Most building companies have a different spec for systems depending on whether it is shared, social or private housing. I also know that the builder's generally won't allow you to have a copy of the plans. Did they give you a copy or is it from the planning application etc?
The system you have set up seems to be done nicely and neatly. The controls are arranged in that fashion to give you an airing cupboard of sorts. You have 2 zone valves in there as the size of the house requires it to have independent hearing zones to comply with document L of the building regulations. The weird looking elbow valve thing is an automatic bypass valve. If the boiler pump was running and the zone valves were closed the auto bypass would open to allow the water to circulate.
It is worth checking under your kitchen sink to see if you have a small potable expansion vessel fitted to the cold pipe. This is needed for this type of installation. It should be a round metal ball about the size of a tennis ball.
Interesting, ok. But when you say "put a radiator in there" I get that you could put a water based one in for what you said, but with an electric one, what power wires would it need to run off of?If in the future you did build an extension and put in another bathroom you could just upgrade to a larger boiler. The above post is right you could just fit a small radiator in the cupboard. Alternatively you could get a plumber to make those pipes longer, they will put out heat when the heating is on. They are designed in that way to not only allow easy access for maintenance of valves etc but also to warm the cupboard so that you do have an airing cupboard of sorts.
I wouldn't bother trying to run power to it in order to add an electric radiator. To be honest you probably don't need one. That pipe arrangement should be sufficient to heat the cupboard. I'm sure you could give a plumber on site some cash and they could fit you a small radiator. It would be a very easy job.
Thanks, very helpful. As this is a Shared Ownership new build with two year developer snags period, would I be voiding any warranties in getting this done? We have already established if I were to change the two zoned thermostats, I would be. I am guessing I may need to wait two years for this also?Yeah that's doable, the pipework would need altering as it's probably on 10mm plastic at the moment. You'd need to get the wall patched after the pipes have been changed. Probably looking at £150-£200 labour for plumbing, £50 for the patcher and another £100 for the radiators and valves. That's a very tough estimate for the area I operate in.
Do you think I should have a moan?Couldn't find a portable expansion vessel, but looks like there is some boxing the pipe work all goes into, so maybe it is hidden?
