this character is one who is not looking for help, I realised that before my first where I agreed with you
I have learned a bunch of things from the responses to this forum post. An explanation for the odd way that the breakers in mu CU are mounted, a bit more insight into the tension between DIY advocates and professionals, how acceptable various methods of mounting a busbar are, and a confirmation that the original mounting system of the busbar and breakers isn't such a great design.
But I haven't learned much from you, except for that it is your opinion that I should hire someone else to do this. You think I'm not only incompetent, but apparently I also do "stupid" things.
OP condemns wiring practices in the country he's working in
I criticize the culture that discourages DIY work because it has a lot of downsides, not just in terms of DIY electrical work. My neighbour is a builder and he's very positive about all the DIY work that we're putting into the house. He complained that young people don't have any practical skills anymore. With plumbing, roofing, electrical work etc. all being discouraged, how is that supposed to change?
OP fails to look at MI's (Shelly)
Nonsense. The reason I'm using this device is because it was a gift from someone who didn't use it anymore. You shouldn't have so much confidence in your speculations about the situation as they are just speculations.
tens of post later he is still too stupid to understand we are trying to help.
It's blatantly obvious to me this character is totally intending to ignore our wiring regs (and for that matter, if I understand correctly, those of the country he seems to think are superior {or possibly inferior, it's difficult to tell} to ours) continue botching until something actually goes wrong. By then the cost of competency is very likely to far exceed the current cost.
I'm definitely not ignoring your regulations. In other work I am putting a lot of effort into making sure that the building regulations are followed. There is a lot more emphasis on building regs here than there is in the Netherlands. I have an opinion on the wiring regs in the UK (which is also my country by the way), but these aren't very relevant as I'm not someone with a lot of authority on the topic. But to clarify:
* UK has the best plugs, hands down. The number of safety enhancing design aspects that barely harm user friendliness is amazing work.
* Fuses in plugs and sockets are great, much better than the Dutch ones where daisy chaining extension cords, which you often see, can have more serious consequences than here.
* UK building regs (and building practices) are soooo considerate of cost saving, which is super annoying and is most costly in the long term (not just monetary)
* In the Netherlands new installs devices for residual current protection type AC have been prohibited since 1996. The UK is VERY late with banning these.
* The amount of paperwork in the UK is definitely a bit excessive, or certification requirements. Like the requirement of an MCS certificate for SEG eligibility. Or the conveyancing process, what a horror show.
* The use of insulated cables instead of uPVC conduit is a bit annoying or at least takes some getting used to. It's quicker though and I guess it reduces opportunities for errors.
* Ring circuits do not seem worth the risk or cost savings compared to radial circuits. The fact that a socket on a ring circuit keeps working if the circuit has been interrupted is not good. I am much more a fan of when it's clear when something's broken, simply because it stops working.
For what it's worth my friend from Kerkelanden is also reading this thread and sending me emails about his posts, I will not be quoting the strength of his words on here.
He's your friend, so it's his job to agree with you. But have a look at the Dutch "
Tweakers meter cabinet" forum with Google translate if you're interested. You'll see that its HUGE for such a small country and that it's all DIY related discussions and advice related to consumer units. There are definitely also regulations there, but people are more relaxed and help each other follow them.
I had a chat about this discussion with a knowledgable person and he raised an interesting point. There is often a difference in attitudes towards DIY installations between field engineers with good knowledge of the regs and engineers with an academic background and a MSc or PhD. The field engineer values the regulations and how they believe things should be done. The academic has a better understanding of the physics involved and is better able to evaluate whether an installation that does not follow the regs is safe or not. Oftentimes though, you'll find that field engineers will equate non-compliant with unsafe, which is what they are supposed to do in their daily job. However, on a DIY forum it's a bit more complicated. In another field I have made the same observation. Nurses will usually be quite dissatisfied when the doctor makes an (authorised) decision to deviate from normal policies, and this dissatisfaction is based on their loyalty to the policy they work under.
No you didn't, you make a hypothetical offer. You said that you would have offered but didn't because you didn't believe I'm competent.
OP lies about wiring practices in the country he's negatively comparing ours with
I wouldn't know where I did that.
And I have done and will continue to do the same, none of us know everything and, despite best efforts, advice may not be appropriate. Frequently where the advisor is not aware of the situation in hand.
The only consequence of this is that I still do the work myself, but without the advice of a qualified person like yourself. Everyone loses with this attitude.
Since working with electricity can be dangerous without certain skills or knowledge, I would argue that the following attitude/policy is more productive: 1. Educate people on how the electrical system in their home works, so they are better able to recognise problems and determine when to hire a professional and what they can fix themselves. 2. Provide quality advice and information to the sub-section of the population who will DIY their wiring regardless of what's recommended (for whatever reason, money, stubbornness, ideals, pride). Let's call this the school of electrical enlightenment due to the emphasis on education, awareness, and empowering individuals to make informed decisions about electrical work while promoting safety.
This strikes a better balance than what I'll call the
school of electrical abstinence.
