Well it is double pole
Then, in the situation you're envisaging, they would not solve the problem, and would pay the price for their 'less intelligence' by having to call out an electrician.Obviously you could. ... Some less intelligent, may just turn them off.
Fair enough, but we're talking about DP switching - not DP isolation by unplugging plugsI would always go for DP, if we go on holiday I always unplug every appliance apart from the fridge freezer, if its a short break .... Well it is double pole
As I've said, I personally see no issue with SP (i.e. no advantage of DP). If people are so daft that they don't try unplugging an appliance which they think may be the cause of an ongoing RCD trip, then I reckon they deserve to face an electrician's bill!"Assuming" the socket is wired correctly, what is the issue with a single pole?
but certainly no disadvantage.
Yes, I suppose that is true - which really reinforces my view.There is, more mechanical parts to fail in my opinion.
If a fault develops in an appliance while the socket is turned off then with a SP switch it may trip the RCD immediately, with a DP switch it won't trip the RCD until you turn it on. This may make it more obvious which appliance is responsible for tripping the RCD.I struggle to think of any advantage in having a DP switch in a socket.
Indeed - and when that happens, it's somewhat analogous to having neutral fuses - which we know is a very bad idea.The problem with double pole switches is when they go wrong. ... You could find yourself in a situation where the live is continuous, and the neutral is broken, and the switch appears to be in the off position.
