But what fool would open up an appliance that is still plugged in anyway??
I would
But only when working inside a PC using the earth as an ESD earth and with the power turned off and tested (with a multimeter).
Saves frying the silicon with ESD.
And the connections on the rear of the switch on the front panel?
And the instructions to disconnect it before opening the case?
Sorry - leaving it plugged in because you can't be rsed to invest in or use proper antistatic precautions is unprofessional and incompetent.
Yes - I've worked on equipment where there's 230V at that switch.Sorry, the ones which have a potential of +5VDC to earth, or are there some others?
If you say so.No such instructions for any modern machine..
And I'm basing mine on what I know to be safe working practices which comply with H&S regulations.At least I'm basing my statements on up to date knowledge.
If you want to be an unprofessional cowboy because you're to lazy or too cheap to bother using or obtaining the correct equipment you carry on.
And what about situations where you have to?Safe working practices would be not touching the bare copper.
Don't you find that a tad limiting, if you're not prepared to work on cables where you couldn't see the plug even if the cable was plugged in (which it isn't) because you're not prepared to follow safe isolation procedures?As I said in the post, which you deleted out of your quotes, was that I only do it on leads and where I can see the plug, that it's out of the wall and the socket is off.
What have pieces of paper got to do with safe isolation, testing for dead, verifying that your tester works etc?I've watched people in laboratories, with PhD's, making mistakes due to their trust in whats on the piece of paper.
I could never have worn a seat belt and say, truthfully, that I'd never been injured in a car crash because of it.I've not once fried anything and don't use any anti-static gear. Turn it off, touch the casing to discharge yourself, unplug it.
No I don't.I think you need to calm down with all the cowboy accusations, as I'm guessing you don't have those things.
Do you also use the one hand method of working with electrics?
{edit}I bet you googled Tim Burners.
