- Joined
- 13 Jan 2016
- Messages
- 12
- Reaction score
- 0
- Country
Ok I understand. That makes sense. Thank you.
So, I have a final £200 to pay before I get the certificates for the whole system from the firm.
The bathroom and kitchen install that I will be doing myself won't be for some weeks so currently there is no way to use the hot water so it's just turned off at the programmer ever since it was first tested.
Also, as it's unoccupied the heating is just on for the coldest part of the night with the room stat at ten degrees.
This means once I start using it all properly in weeks to come if I do need anything adjusted I will likely attract charges from the plumber surely?
If everything can be set up correctly first time around then it's all included in the price obviously. Unless I should expect "free/ included" after-service for any adjustments?
I don't want to hold back the £200 and the certification for weeks, it doesn't feel reasonable but maybe that's what I need to do?
Cheers.
Cheers.
