"Vertical" oil tanks are cheaper than "horizontal" ones. If space isn't an issue, do horizontal tanks have any advantages that make them worth the extra cost?
If your situation requires a secondary bund click for Explanation then a vertical probably will have no space saving advantage given the size of the necessary bund.
The horizontal one does have a slightly smaller footprint (2.50m2 vs 2.64m2) but occupies a considerably bigger overall area (3.41m2 vs 2.64m2) so I'm not sure that's much of an advantage. In fact, OFTEC say the base should extend 300mm beyond all sides of the tank, which might imply that the horizontal one would actually need a considerably larger base even though its footprint is a bit smaller.
The horizontal tank is less than 4 inches narrower, but nearly 2 feet longer. Obviously if you simply couldn't squeeze in those few inches of width but had plenty of room the other way then the horizontal would be the only option, but that's likely to be a tiny proportion of cases. That made me wonder if there's some other advantage of the horizontal that I'm missing, otherwise it seems they would be fairly pointless in most circumstances.
But for a "tradditional" bund ( an oil proof and empty "pond" under the tank ) the foot print area A is determined by stored volume V and depth of bund D
A = V / D
How resistant to attack with malicious penetration are tanks with integral bund ? Risk assessment ?
