Old Electric Meter
That 2nd fuse in looks damaged at the bottom right corner.
Switch off the main switch before pulling or inserting fuses.
and after inserting/replacing fusewire and with the fuse cover on before switching back to on. A flash bang fling of hot lumps of fusewire closing into a fault can splatter all over and can get in yer eyes.
A 30A fusewire going BANG into a dead short fault can make a noise you tend to remember, there are plenty who have tried it.
Got that tee shirt many times lol. You soon learn to look away before switching on.
However In my experience a fuse blowing has always been perfectly normal when a bulb blows.
One of my first jobs on the side was for my mothers friend, 5 amp fuse had blown when a bulb popped, replaced the fuse wire, circuit still dead, took about an hour to spot a tiny blob on the fuse carrier caused by arcing which was preventing contact somehow
Working in Africa I had to switch in an 11kV substation on an airforce base , chief engineer & the contractor gave the ok, switched the RMU and the substation lights went out, whoopsie
In my inexperienced youth, I was working in the back of a panel, connecting a temporary, bare earth wire. The back was just a large, plain, completely empty space of paxolin, apart from screw heads scattered around it, for equipment on the far side. Unknown to me, and it seems everyone else, the screw heads were all live, with 3ph. Bare 7/044, or something similar, was to run from top to bottom of the panel. Well, the wire caught on one screw head, welded itself, and tracked up to several more, protected by 100amp fuses. The flash lit the place up, and I was completely blind for several hours.
Me too.
Been to hundreds of calls outs for just that.
Quality lamps (the old tungsten halogen type) had Ballotini fuses built in which would pop to stop the circuit protective device going, but cheap ones didn't.
Me too.
I've never known an actual fuse-wire go, due to a lamp failing, I have numerous times had MCB's trip, when they have. The reason is fuse wire has much more inertia, to fault currents, than an MCB.
My recollection is completely different, AFAIC blowing a fuse was completely normal. Originally I assumed it was the break in the element shorting across to the other support wire. I tended to store spare carriers by the fusebox.
Not as long ago as that Harry
Indeed. The Wylex boxes were available well into the 1990's, I purchased an 8 way to upgrade the installation in my home and Mrs Sunray points out we moved in November 1994.
Snap! I fitted 3036 boards in 94 too.
Bearing in mind we moved 6 weeks before Christmas and also there was lots to do to the place the fusebox wouldn't have been a high priority to would have been well into the following year and possibly the year after but I have no way of telling now.
EDIT: Except of course the photos and May 1996 seems to be the time we altered the hall which included reconfiguring the under stairs cupboard and that predated the fusebox change.
I’d say fuse blowing if a filament lamp blows was less common than an MCB tripping but both could occur on occasions anyway. Whatever the ratio it is usually noticeable but not exclusive.
