I hear the sound of straws being clutched at.
Sounds like it's being used as a cutout though.Because you don't know what you're talking about, its called a switch fuse.
The description mentions 4 sets.Ureavinalarf, apart from the picture being complete nonsense, it misses out two or three sets of cable. You're description mentions four or five sets of cables.
1: the mains supply comes into the cut-out box,
2: out to the meter,
3: then back into the cut-out box from the meter
4: and out to the c/u
Indeed it doesn't - something you would do well to bear in mind yourself when posting.You obviously think that 'b***s*** baffles brains' - it does'nt.
Can you give me an example.
Don't switch fuses usually have the switch upstream of the fuse, so that when off the fuse can be pulled/inserted with no live parts accessible?Because you don't know what you're talking about, its called a switch fuse.
What's he invented? Interlocks on switches to prevent enclosure doors being opened without turning the switch off are commonplace.So you've invented a new type of lock, you call it a switch lock.
You're as thick as the other bloke if you think this drawing resmbles your description.
And HullMark's drawing shows 3 of them, so misses out 1 set, not 2 or 3.
could imagine tails to the CU from the LHS of the isolator?As a very experienced electrician
the gist of what I was talking about (the responses even included a remarkably accurate picture).
Well it was neither my drawing nor my description, but never mind.You're as thick as the other bloke if you think this drawing resmbles your description.
