Hello all.
I have an old workshop in my garden - it is older than the house. The previous owner of the house put an armoured cable to the workshop (6mm) about 50m away, but this is too small and the striplights go off and restart when I start my circular saw (takes about 12A on startup).
To compound matters there is another shed much nearer the house, and this is supplied with another length of 6mm armoured from the first workshop.
I haven't asked an electrician yet (which I do plan to do), but rather than digging up my wife's prize garden to add a new length of armoured all the way to the workshop, is it feasible (and allowed) to simply run a new supply to the small shed but keep the existing cables (putting new rcd's etc where necessary) so as to make the garden into one large ring main with two outbuildings? This would mean that the workshop would effectively be at the end of two lengths of 6mm armoured instead of one.
Alternatively, could I have the new supply added to the nearer shed, and then divide the workshop supply into two so that the saw is on one armoured run and the lights on a different one (with a new consumer unit in the workshop for the lighting etc)
The supply comes from a separate box straight from the meter in the house - both of these supplies would come from the same box and RCD, so would not be on different phases etc, just taking a different route.
We had the house rewired recently, and the workshop supply consumer unit in the house was replaced, but the electrician sucked in his breath when he saw the size of the cable to the workshop… He would only put a 20A trip in because of the size, and even then he wasn't happy.
Any thoughts anybody?
Pete.
Pete.
