If you think the condensation might be from cold draughts from the window seals
If a cold draught is causing the window glass to be cold, the water vapour from inside the house will condense on the cold glass.cold draughts from outside don't cause condensation. They are fresh air. They contain less water vapour than indoor air.
I mean put masking tape all around the joint between the window and the frame on the inside to stop the draught.Thanks lower. When you say seal the window with masking tape, do you mean cover the rubber gasket with masking tape?
Also do I put the masking tape on the inside or outside or both?
