From what I can see the pump looks like it is on the flow from the boiler and the magnaclean is on the return.
I may be wrong. I would therefore also assume that an auto air vent would be installed on the return pipe from the boiler or there is one inside the boiler.
If I'm right, I think when the pump runs pushing water away from the boiler, any air causing the float in the AAV on the return or internally to drop, allows more air to be pulled into the system until the next glug of water forces the float in aav back up again. Then a plug of air comes round again etc etc etc.
I've only skim read this thread so might be a clog out. Move the pump onto the return
