Harry, I read your posts here - and have read quite a few of your, many, others. Do I remember you saying that you weren't, actually, a Gas Safe installer who fits boilers yourself?
I am long retired.
Now, my new boiler has been in since July so I've had a few monthly gas bills in, with the gas usage detailed to the n'th degree, and my Mrs and I use the shower every day, albeit not at the same time (that malarkey stopped a good while ago
) Furthermore we've had some cold weather in recent weeks so I've been able judge how well the boiler actually functions in winter and whether or not the burner spends all day cycling on and off (it doesn't).
The economics will vary wildly, depending on how your heating is used, and how you use hot water. I have never said a heat only, is more economical in all circumstances, because it is not.
So, Harry, the reason I've written the above is to offer my own personal, hands on, from the horses mouth, experience of using a 32kw Ideal Vogue Max Combi boiler and to ask you, Harry, to justify your comments about poor efficiency and low water flow from the shower.
I have never suggested there would be an inadequate flow from a shower, that is one of the things that a combi excels at doing. What I have said, is that a combi will be much slower than a system with a cylinder of hot water, to fill a bath. To the good, the combi can provide unlimited amounts of hot water, without delay.
To the bad - each and every time you turn the hot tap on, you waste lots of water, and lots of gas, waiting for the heated water to appear. The gas has to heat the heat exchanger, then the water, In order to have the Kw available to produce instant hot water. Often, that can mean the Kw of the boiler, needs to be twice that, or more, needed for central heating. Everyone agrees, that a boiler Kw which is too high, makes them less economical.
You said you have had your old boiler, replaced with a new modern one - of course it will be more efficient.
You claim to be a competent DIY plumber. As such, you should be aware, that nearly all the clever gubbins, which can fail, is tucked away inside that boiler casing. Which means most of the issues with your heating and hot water system, which once on a heat only boiler system, you could have fixed your self - now need a GSR engineer to attend.
This is all old ground, all covered at length, so I will not be drawn any further into the pros and cons, of combi v heat only boilers. This is dannyboy85's thread, it is rude to kidnap it..
