But there's an update! Today a WB engineer coincidentally got called to next door which seemed too much of a coincidence to refuse! A few smiles later and he instantly identified the heat exchanger had gone on the boiler and replaced it.
Hi I have a similar problem with my boiler. the engineer installed it two weeks ago, and all worked fine. But now the heating works perfectly but when we switch the water on it heats up to temp then cuts off.
It's a Sime digital format, and the engineer has been out three times, and worked on it for about 10hrs with no luck. he is stumped as to the fault.
