As you have worded the question, no, you cannot - but what you have is not two circuits, downstairs lighting circuit, so yes, you can.
Two circuits would be separate from two circuit breakers when obviously you would not actually be able to have one switch for two circuits.
Thank you, I appreciate the help especially given the wrong terminology. I am planning to change my CU in the near future and have a seperate circuit for the outside lights, but in the meantime, could I go for an RCD protected fused spur (like this one: https://www.screwfix.com/p/british-general-900-series-13a-unswitched-passive-fused-spur-white/8250p) instead of the 20A DP Switch? Initially I will have 6 5w led bulbs connected and then in a couple of months I'll have the wiring switched over to a dedicated circuit when my new CU is installed, however at the present my downstairs lighting circuit is the only one that is not on an RCD
