Thanks for comments guys.
Just as clarification for @RickH. There is indeed an option where notifiable electrical work can be carried out by a competent DIYer and for that the work to be certified and notified by a third party electrician.in Wales third party signing for work is not permitted, this is only allowed in England.
Thanks for this explanation - the LABC say this was the case, but the door has been closed in Wales, and no longer acceptable for anyone other than the original installer or them to certify new workJust as clarification for @RickH. There is indeed an option where notifiable electrical work can be carried out by a competent DIYer and for that the work to be certified and notified by a third party electrician.
BUT BUT
the rules are
1. the electrician must be registered with his competent person scheme (CPS) as an Electrical Third Party Certification Scheme member. Not all CPS do this. And being a Third Party Certifier is an additional cost to the basic CPS ££. Also its a PITA and not many electricians take this up.
2.When electrical work is to be done by the DIYer and certified/notified by the third party electrician, then the electrician must be engaged before any work starts. The electrician will visit to specify and oversee the works (first,second fix, etc) so that he/she can ensure compliance with regulations. It is not a retrospective "sign off".
Theres more about the Electrical Third Party Certification Scheme here.
Electrical Third Party Certification | NAPIT
The Third Party Certification scheme allows you to check and certify domestic electrical work undertaken by others via inspection and reporting procedureswww.napit.org.uk
I'm afraid that you only have one option, and that is to suck it up, and pay LABC. Sorry.
The door was never open in Wales nor England.Thanks for this explanation - the LABC say this was the case, but the door has been closed in Wales,
Indeed - that's close to a much naughtier variant of that which was the first thing that came into my mind, but which I wouldn't dare mention/suggest here!Just remove it and get your friendly electrician to reinstall it. Surely in a garage it's all surface mounted. You could probably act as "electricians mate" and do most of the work under his supervision.
I think your in cloud cuckoo land. Trying to play silly with LABC inspectors just means you will get do it again and do it properly. I did manage to get them to back down, by asking for their inspector to be higher qualified than myself, and my training is to level 5. And I did have C&G 2391 etc. And all the meters were laid out for him to see with all the calibration certificates. So in my case he was trying to say two fully qualified electricians were not good enough to sign their own installation certificates.If you are prepared to be more bloody minded than the officials, then eventually they'll get told to back down by their superiors - especially if you keep escalating it and making ever higher level council officials look like jobsworths.
I think that's only the case if one 'gives up too easily'.I think your in cloud cuckoo land. Trying to play silly with LABC inspectors just means you will get do it again and do it properly.
For some of us, "it's a matter of principle" from which there is no backing down.However, one regards all the hassle as worthwhile is perhaps a different matter.
My inclination is exactly the same, and I try to adopt that approach whenever I can. However, there are probably times when I really should (but often don't) allow that to be trumped by 'pragmatism'.For some of us, "it's a matter of principle" from which there is no backing down.
