[shrug]Simple solution to that - don't post here and make it mine.[/shrug]No offence Ban-All-Sheds but none of it is any of your business.
Have you worked out what (iii) will cost?Option (i) would probably be the quickest, but cost the most money.
Then buy the test equipment.I'm a maintenance engineer for a reason, I just like doing stuff. It's what we do.
Great opportunities with rewiring to leave floorboards lifted for a while - guaranteed to annoy.It also drives my missus up the wall, which makes it even better !![]()
Free yourself from the notion that you can contribute to a discussion on an internet forum with material arising from your incompetence and professional negligence and not have people who are just as entitled to post as you are remark on your incompetence and professional negligence.Jump down from your high horse and let the horse go![]()
You'll be lucky to get an all-in-one for £300 though.
We send so much stuff away for cal each month that i'm sure they might give me a freebie if i get the storeman ( who deals with this ) to ask.If you have test kit at work could you get yours calibrated on the sly?
And have you thought about getting a power wall-chaser?![]()
I asked you a question - big deal.You asked what if I couldn't arrange completion?
Not a lot.What exactly does this have to do with you
It doesn't, at least not as much, perhaps, as it concerns you, your client, and possibly her solicitors...and why does it concern you?
Fair enough. All I was doing was to point out that your critical tone was inappropriate given that you had invited comments and questions by telling your story here.I have chosen not to answer this question as frankly it is none of your business. Its that simple.
Hi Robert.
For your last paragraph are you talking about work that is or isn't covered under a job that required a building warrant.
Old-fashioned apprenticeship some 40 years agoAre you a qualified and practising Electrician.
A bit open-ended so I'd need to see it first. I'm not prepared to swap the CU without seeing the state of the house wiring and I'm not prepared to connect the garage circuit unless it's all visible. However assuming that I think the wiring is fine a CU swap will likely take me a couple of hours so maybe a morning all-in. But I take it from the word 'modern' that maybe you should be considering a rewire or at the least an inspection?Roughly how much would you charge to do the work i require doing which is replace a C U for a new modern one and install a new shed circuit ( I've already bought a brand new MEM 2000 2 way garage CU for this).
If there is no legal requirement for you to supply one, then asking for one is inherently unreasonable.Also on the example of an electrical certificate for a newly installed kitchen how could they reasonably ask for this given there was no legislation in place beforehand that stipulated this was necessary.
