PS - "the floorlayers will be using welders"![]()
Ye 10mm steel plate flooring is all the rage these days
I am guessing from your question that you are being told by the main contractor that you must have your equipment PAT'd before going on site.
As others have said there is no fixed time period laid down anywhere but for construction sites the suggested norm from the IEE is a full Inspection/test every 3 month formal visual every month and a user visual WEEKLY
The main contractor will also enforce their own H&S policy on top of the guidance so in a nutshell if their policy is a full visual and test every week thats how often it needs doing. Usually though they go with the IEE guidelines.
Tell them it varies from site to site, and that they have to check with each one before they start work.
Suggest that they only equip themselves with 110V tools and also buy a portable site transformer for when they're in environments where 110V isn't available.
Now the BS7671:2008 has the same rules for a 55-0-55 supply and a 230v supply and both must have an RCD with socket under 20 A (411.3.3) ......
Matty, site tools should be fully PAT tested every 3 months. Some sites will insist on tools being PAT tested by their sparks they day you start on site. No big deal really, I've had drills etc PAT tested almost once a month some years back. One drill I owned had more stickers on it than a F1 racing car had adverts.![]()
