joe-90 said:Let me explain:
Imagine I have a roller skate in my hand and I sit it on a conveyor belt. Now if I move that roller skate by applying thrust (through my arm) and move the roller skate forward, it matters not what the conveyor belt is doing, it cannot stop me moving the roller skate forward
joe-90 said:- and it's the same with the jet. It matters not what the conveyor belt is doing, the Law of science applies to the 'equal and opposit reaction of the thrust'
joe-90 said:. Just as my arm would push the roller skate forward - so will the engines push the jet forward to take-off velocity.
joe-90 said:Geddit?
Eddie M said:Spark123 said:Some info on aerofoils here:
http://en.wikipedia.org/wiki/Airfoil[/QUOTE]
I did say it was a loaded question, I don't think I necessarily believe that fliud dynamics (non compressible system) correlate to a gaseous system (compressible), this is how planes are believed to fly (Bernoulli’s principle).
You will have to hunt high and low for a good explanation, 'cos even the NASA websites hasn't convinced me yet.
It's a very complicated and hotly contested subject, and one I am willingly able to say that I don't understand, but nevertheless interesting.
The way I understand it is air velocity x pressure in the vacinity of the wing will be a constant. If you increase the airflow you decrease the pressure (create depression), likewise slowing the airflow creates pressure. The pressure causes the wing to rise into the depression. (Not 100% true I know as there are many other factors to consider.)
Spark123 said:The shape of the wing means the air has further to travel over the top of the wing than the bottom. Since the airflow has to cover this distance in the same time as the airflow on the bottom of the wing (relative to aircraft speed), there is less pressure above the wing than below it. No momentum through the air = no airflow = no lift.
Are we going for the full 10 pages?
Spark123 said:So the answer is yes, the plane will take off.
If the conveyor belt moves in the opposite direction to the wheels (at equal but opposite speed) the only result is the wheels will spin twice as fast as they would normally. The aeroplane will still move, the lift of the aeroplane is given by the speed of the air over the top of the wing being faster than the speed of air under the wing resulting in a depression above the wing and hence lift.
johnny_t said:Aha !! So, for example, and assuming bearing friction was less than the air resistance, if the plane was just sat still and not thrusting, and then you fired up the conveyor belt, would the plane stay more or less still, and the wheels just spin underneath it ? Is that the key to all this ?
