Bas is obviously not on DIA's ignore list....
Thanks for the message bas.
Typical rantings of an Old tart with dementia and a shortage of active brain cells. Do you still wet the bed
What if the boiler is changed?
No. You don't seem to have grasped the last twenty three pages.A proper electrician does come to a job where the earlier installer, for arguments sake a heating engineer or DYer or sparky not up to date, has put in 3 core on an analogue stat, Live in, Neutral, Switched Line back to whatever, boiler or valve. No earth core.
What would you expect the electrician to do?
1: Put another analogue stat in that requires no earth in the manufacturer's instructions (though he knows the regs say the cable should contain an additional CPC even if it's not used).
What are you talking about?2 Put a digital stat in that requires only line in and switched out using say the neutral core for earth and sleeved but not connected (don't know if that is allowed but there would then be an additional core to use as an earth later).
Not necessary.3: Re-run the whole lot again removing carpets and boards etc.
The cable isn't a no-no. It's the plumbers' use of the cable that is the no-no.4: Putting in a wireless stat but cutting off the old cable so it couldn't be used again is a no-no because you can't find one that's suitable (obviously I'm being awkward here but just for the sake of discussion not argument).
Put in a thermostat that doesn't require a NEUTRAL.
Connect the CPC at the wiring centre.
Use Brown for L in, Blue for SL out and G/Y for CPC
I am beginning to despair.
My apologies.
I mistakenly thought you were another doitall.
My apologies for making you despair. I asked the questions politely and might well have been asking because possibly I didn't grasp the previous 22 pages.
I believe I do and took pains to be quietly inquisitive rather than confrontational.
What difference would it make? Have I written anything which is incorrect?Are you actually registered with any body.My apologies.
Be interested to know what they say.
