Sorry for my ignorance what is R17 ?
'Impossible' is probably not the right word, but if immediate remedy would be very difficult, I have already suggested that the pragmatic approach might be to accept an oversleeved G/Y-insulated core (of flex) as a live conductor (and the consequential absence of a CPC in the cable) - if that is what is being suggested. However, that only deals with part (a) of ecowarrior's question. As for (b), if this is what is being suggested, I think I would personally draw the line short of having anything to do with the ongoing use of a bare CPC as a live conductor (even if sleeved at its ends) - except, conceivably, as a genuinely very temporary situation before I remedied the unsatisfactory situation in the very near future. It would, however, virtually always be possible to provide a 'temporary' surface-mounted proper cable (even if involving a circuitous route), 'to get the heating back on', until such a time as 'neat' proper wiring could be installed.To answer your question truthfully - If it were absolutely impossible to remedy I suppose it would have to be left.Lets just say you have been called to swap this zone valve head over ( certainly within your remit) - what would u suggest be done on seeing a: a sleeved cpc and b: a sleeved bare cpc? Getting the heating back on depends on you. What do u propose?
Yes, that was what I meant in my slightly sarcastic (me?) comment about swapping it for the conductor which was being used for the cpc.I'm a bit confused, because don't zone valves need an earth connection (hence a CPC used as a CPC)?
I don't think there's much scope for interpretation. As has been explained, the regs explicitly require all cables to have a CPC (even if an earth is not currently required by whatever is connected to it), and there is no exception made for heating control cables. It sounds as if you probably should be using 5-core, not 4-core.Further to the (I am sure correct) comment about all cables must have a cpc even if they are intended for use with double insulated kit. How far does this apply to heating controls?
If fitting a WiFi stat receiver (0v or 230) I currently use 4 core ( all black) flexi and sleeve the L&N brn & Blu and the other two red. ( or unsleeved if ELV) The Rx box does not claim double insulation – but nothing needs an earth. Are u interpreting the regs to say this should still have a cpc in it?
Ah, I did rather wonder what you were getting at with that comment - maybe I should have read your post before opening the bottleYes, that was what I meant in my slightly sarcastic (me?) comment about swapping it for the conductor which was being used for the cpc.I'm a bit confused, because don't zone valves need an earth connection (hence a CPC used as a CPC)?
Yep.Further to the (I am sure correct) comment about all cables must have a cpc even if they are intended for use with double insulated kit.
Equally.How far does this apply to heating controls?
Yes, but why does it not?If fitting a WiFi stat receiver (0v or 230) I currently use 4 core ( all black) flexi and sleeve the L&N brn & Blu and the other two red. ( or unsleeved if ELV) The Rx box does not claim double insulation – but nothing needs an earth. Are u interpreting the regs to say this should still have a cpc in it?
A water regulation I think.Sorry for my ignorance what is R17 ?
If I ever trip over thin sheathed 5 x .5 c able I may well. From a practical point the 5 core .75 is so big in diameter to not clamp into many new control boxes.Why would you not use 5 core?
http://www.csecables.com/acatalog/YY-Cable-5-Core-0-5mm2.html
Ooooh. That's not good.Earth for the boiler comes via the main bond or not at all if its all plastic
