S
SaladFingers
If we spent less time slagging each other off ( well some posters) and more time explaining each others issues we would all be that much wiser.
I'll second that.
I am not condoning or promoting any of this. Some one asked for an example of when it can happen & I offered on instance.
OK some boiler manus state that as the 'bonding' (if rerq) doesn't need to be done with bonding straps & cable as the boiler will do that for u. Nothing to do with how it works, what it does, or what its called. Just to tell u that u dont need to do it on that particular boiler.
Yes all boilers must be earthed but only those that need functional earths will show an obvious (visual) issue if they havnt got one.
Yes its supplementary bonding but it would help if they stopped changing the names of things. (equipotential & main etc)
Plumbers (understandably) did suffer from bonding mania. To level all the incoming earths & various supplies & the pipework it does make sense to do it in the one place most of the pipes are bound to be in close proximity (by the boiler) with main bonds from incoming gas & water & lekky.
To me R17 is the line in the sand for full domestic protection or not. As supplementary bonding is not needed in properties with all ccts protected by RCD's but anything earlier still is, to protect special locations etc.
Fair enough.I am not condoning or promoting any of this. Some one asked for an example of when it can happen & I offered on instance.
But it is never necessary when the boiler itself is not in a special location.OK some boiler manus state that as the 'bonding' (if rerq) doesn't need to be done with bonding straps & cable as the boiler will do that for u. Nothing to do with how it works, what it does, or what its called. Just to tell u that u dont need to do it on that particular boiler.
See above answer.it does make sense to do it in the one place most of the pipes are bound to be in close proximity (by the boiler) with main bonds from incoming gas & water & lekky.
I still don't know what R17 is. Is there a link to it?To me R17 is the line in the sand for full domestic protection or not.
No, but the supplementary bonding is for protection under fault conditions when the RCD will disconnect the supply.The thing is RCDs play no part in protecting from differing potentials across metalwork.
As I said above, plumbers only demand (cross) bonding of the pipes and not to the boiler so it does not bond the boiler to the pipes.I believe if all fittings are metal and there's adequate conituity directly from boiler to pipework, then cross bonding is a waste of time anyway.
All boilers, surely.Most boilers require earth from the controls supply, so the boiler is 'earthed' in anycase.
Which meant people were doing things without understanding why.For non electrically minded plumbs - good practice was to cross bond under the boiler.
That can easily make things more dangerous not less.In the kitchen this often went a bit OTT with anything metal being attached to each other as well as the pipes.
That was me - that was the only relevant thing that came up on Google.and another poster surmised it was a water reg -
Yes, under fault conditions.No, but the supplementary bonding is for protection under fault conditions when the RCD will disconnect the supply.The thing is RCDs play no part in protecting from differing potentials across metalwork.
No, it's not. Supplimentary cross bonding is to ensure all metalwork is at the same potential.
Ummm. Not sure what you mean by 'rely' but - one which is trying to get to earth?What fault would rely on pipework?
But if someone else's pipework is connected to it, what will happen to that pipework when a fault occurs?Electrical equipment will be earthed in its own right, not protected by someone elses pipework and supplimentary bonding.
What does it take to get some people to realise that they are incompetent and must not do electrical work?
So why have you decided to continue that tradition?Earthing, bonding and supplimentary bonding has been widely misunderstood for decades.
R17 is my own 'name' for Reg 17 on .
