Pressure dropping in CH - Vokera Combi
Update
Ive drilled a couple of holes from underneath and like i presumed no leaks whatsoever
Ive checked all rads in house and no leaks
So ive contacted the boiler insurance and they are comming out tomorow, i know they will say it is due to the work ive recently carried they will sure try that one
ill update once theve been
Regards
Kev
Update:
The engineer came and said it was either air in the pipework (reason for pressure dropping) or a leak
Advised me to put some fernox f4 leak sealer might take two doses but that should stop the leak
Whilst he was here he showed me how to release the presure, dead easy with the switch in the boiler, but his now may have caused a problem as im now getting a small drip from the outside pipe,
Hes comming back next week to fit me a new filling look as the plastic knob has snapped off the part where i add more water to the system
ill keep you updated
Kev
Update ;
New filling loop fitted, and 2 tubes of fernox f4 concentrate in system
Ive checked under floorboards for leaks and found nothing at all
My pressure is still dropping to 0.5 - zero over 2 days
Surely my boiler must be at fault
What can it be any ideas
Im going to call the engineer out this week
Kevin
