Hi PrinceofDarkness
I do understand what you are saying but my argument is that as you are measuring your PFC at the incommers, there isn't anything of 'appreciable impedance' to affect your reading as any impedances are taken into account when your meter calculates the prospective fault current that could flow at that point.
And to be honest, an MCB is of negligible impedance, so even measuring with this in the circuit would give a reasonable idea of maximum pfc.
But the Maximum pfc is different to the 'actual' fault current, because, as Ericmark correctly pointed out, the protective device limits the fault current flow by operating fast enough to cut out before it reaches that level. But you still need to take the maximum into account in case it doesn't open fast enough and the full fault current flows.
I didn't mean to have a pop, it was more to do with Ericmark's patronising manner, implying that it shouldn't be posted on here because none of us will understand.
I've seen some c**p posted on that IET forum
