Would like a bit of guidance on protective bonding
An installations gas service has main protective bonding connected to the MET (3 flats looped on one 10mm G/Y conductor)
The water enters in plastic, in a communal hallway, it then runs in copper from the hallway into the flat.
The water service enters in plastic, changes in to copper, and runs up the wall to the flat
(It does not go back into the ground)
There is no bonding connection visible on this pipe. (The incoming water was changed from lead to plastic a couple of years ago) I suspect water was never bonded.
This water pipe now does not required MPB, as it not an extraneous conductive part?
But in my mind it is now an exposed conductive part as it is connected to a boiler, which has a connection to a 230v source?
They will be a ‘Earth' connection to the water pipe via the boiler manifold to the boilers CPC connection, and the gas pipe which is bonded.
But would it be advisable to add supplementary protection to the water pipe.
The towel rail in the bathroom tests at 4.69kΩ to the MET which suggests it does need bonding.
Testing gas and water in the kitchen to the MET (Disconnected gas bond), I get 0.08Ω (Boiler manifold probably providing then low ohm reading on the water pipe work)
Plastic push fit connectors on plumbing evident
Testing the towel rail in the bathroom to MET I get 4.69kΩ which has left me a bit unsure what to do.
Testing between the towel rail and the bath taps, I get a similar reading 4.56kΩ, which is quite a high reading, I would expect a reading in the low ohms.
All circuits have RCD protection.
It suggests that supplementary bonding is required?
Hope that make some sense
