Guys and girls, I need your help!
Have had problems with the rads getting hot even when room stat was on `0`
Have replaced the 2 port valve for the heating circuit. Problem is now that the pump and boiler will not fire.
On the H/W valve, it opens, makes the switch and I have power going out, but the pump supply is dead.
If I take a wire off the live outfeed from the H/W switch and put it directly onto the pump terminal, the pump runs and the boiler fires up.
Could it be as fault with the programmer? As i know that the pump and boiler are ok?
Thanks in advance
Danny
Thanks in advance
Danny
