Query from the Combustion Chamber......................
Isn't it the case that pipes which are 'part of the installation' may be used as supplementary but not as main. However, surely an additional (metal) pipe could be used as either.
Exactly. I see nothing in the regs which says that a copper MPB conductor can't be hollow, or that it has to be insulated - so, if it is not a pipe being used for other purposes, I don't see it as being any less acceptable as an MPB conductor than is standard G/Y cable.
Kind Regards, John
I don't think you are allowed to use an oil pipe as a protective conductor, can you guarantee it is free of any oil residue?
As for the continuous PEB looping to two services I believe it is a take on a reg regarding work on one of the services should not effect the other - haven't got my regs book to hand to say for sure.
But as there is one which explicitly allows it for supplementaries, and there isn't one for mains, my interpretation is that is is not allowed
This is the problem of a book of 'regulations' turning into a book of specifications because people started to add bits to avoid questions like "Can I use a bit of pipe as a supplementary protective bond?" becoming a contentious issue in the workplace.
Anyway, you can't use the pipe as a main protective bonding conductor:
The IET said:
543.2.3 A gas pipe, an oil pipe, flexible or pliable conduit, support wires or other flexible metallic parts, or constructional parts subject to mechanical stress in normal service, shall not be selected as a protective conductor.
I would still class it as an oil pipe as although it's not in use the oil, importantly the flammable bit, will remain at the bottom unless it's been properly flushed, cleaned, and dried (which I very much doubt).
Other than that, 543.2.1 and 543.2.6 permit using pipework as a protective conductor in certain circumstances. Don't forget to read 543.3 also.
Probably not, but I would say that it's the oil, not the fact that it used to be an oil pipe, which is the issue. If it were a brand new, unused bit of pipe of a type used to carry oil, I would see nothing to prevent it being used as a protective conductor. Regs-wise, it's all matter of whether 543.2.3 regards an 'ex-oil pipe' as an 'oil pipe'.
Yes, that's why it's 'good practice' not to have the 'looping' part separate from the rest - but, as you say, it requires a bit of interpretation of regs (about which people probably wouldn't agree) to find a reg which actually insists on that. I was talking more generally about the (AFAIAA untrue) belief that some people have (including, I gather, NIC) that the regs insist that the main run of an MPB conductor cannot have any joints in it. I don't believe the regs say, or even imply, that, anywhere.
Kind Regards, John
Unless the pipe can be tested for prolonged continuity with an acceptably low resistance ( testing with a few amps of test current ) I would not use the pipe. There could be a joint buried in the screed which may not be a good electrical connection but due to the surrounding screed did not leak oil.
Using a high current test will ( hopefully ) burn out any weak points.
Unless the pipe can be tested for prolonged continuity with an acceptably low resistance ( testing with a few amps of test current ) I would not use the pipe. There could be a joint buried in the screed which may not be a good electrical connection but due to the surrounding screed did not leak oil. Using a high current test will ( hopefully ) burn out any weak points.
I can't disagree with any of that, but I think this tangential discussion about using the pipe istelf as a conduction is a bit irrelevant. EFLI and myself both mentioned it as a theoretical possibility only really so that we could dismiss it - and I really don't think that anyone should be seriously consdiering it as an option.
The OP's greatest hope would seem to exist if the water service MPB is connected fairly close to where the gas service needs bonding, in which case the existing bonding conductor could be 'extended' (as others have pointed out, preferably by joining the cable, not by have a 'loose' bit of cable between the two services).
Kind Regards, John
Or as suggested recently, which I had not thought of before, fit an earth block nearby.
Are you refering to my suggestion in a recent thread when a bonding conductor was 1 metre short of reaching the CU?
Anyway, yes, one could obviously use an earthing block 'at the other end' (near the point of bonding to water and gas services) - but that would really just be a mechanism for achieving the 'joining of conductors' I mention above, not really a 'different idea', wouldn't it?
However, unlike the situation in the other thread, one would presumably not want to regard that earthing block as the MET, since the OP would then be really be back to square one, since there would then be a need to run an Earthing Conductor to this 'remote MET', and a cable from it back to the CU!
Kind Regards, John
Yes, excellent idea.
No, not as a MET, just a solution to adding the bonding of a nearby service, the removal of one leaving the other(s) intact, and to which no one could possibly have any objection.
Or - could they?
No, not as a MET, just a solution to adding the bonding of a nearby service, the removal of one leaving the other(s) intact, and to which no one could possibly have any objection. Or - could they?
You'll have to ask 'them' :) I can bit presume that those (and there do seem to be at least some) who believe that MPB conductors must be continuous (all the way from MET to extraneous-c-p) would object to this just as much as they would object to any other type of joint in the conductor, wouldn't they? ...
... but please don't count me amongst 'them' :)
Kind Regards, John
... I should have added that what we've just been talking about is exactly how MPB to my water and gas (LPG, from buried pipe) is arranged. In fact, the conductor to one of the services is continuous, all the way from the MET to the bonding point. A couple of feet from that bonding point, the conductor goes through (and thereby is connected to) an earth block (a bit of its insulation having been cut away), and a second bit of cable goes from the earth block to bond the other service.
Kind Regards, John
I don't like the idea of it being disconnectable, a crimp and some heat sleeve allowing it to be looped would be my method. I think lec said similar to this before.
My copy of GN8 (albeit from 2006) says that it should be unbroken thus maintaining continuity to other ecps should one be disconnected for whatever reason. Don't have the 2012 version yet but I can't see it saying much different.
It will be fairly obvious where the MET is, if you go installing additional earth martialling bars around the place then that is up to you, I don't like the idea.
I can understand your view, but there is really no reason why anyone would/should ever disconnect connections from the earth block - if they were working on one or other of the pipes pipe, they would presumably disconnect from the pipe. If you really were worried, I suppose you could put warning labels, take steps to deter inteference with the earth block, or even put the earth block in a sealable enclosure (or use a Henley, rather than an Earth Block, so that it can be sealed). I do agree that a 'loose' piece of G/Y joining the two pipes is not a good idea, since someone removing the connections from the 'first' (closest to MET) earth clamp, to work on that pipe, could easily leave the other pipe unbonded.
Of course, some people would be more comfortable with an inspectable and retightenable screwed connection than with a crimped joint in the MPB, so the arguments aren't all in one direction, even for the ultra-cautious.
As EFLI has just asked, and as I asked recently (in another thread), what is the difference between the earth block we're talking about and an 'external MET' - the MBP conductor can be disconnected from either by anyone with a screwdriver.
Kind Regards, John
