You wrote-
That doesn't prove the condition. You would get contiuity through one strand off a 0.5mm² flex. Doesn't make it a reliable connection
Can i just point out with this on thinking about it that no test really prove the condition of any type of cable for instance a cable buried in a wall could have its outer sheath damaged and possibly an inner sheath and all tests could still be satisfactory you would never know until you dig it out and look at it properly or it causes tripping? same as if the water pipe was damaged it would leak and a pressure test could be done to confirm some sort of condition??
Whats to stop someone cutting a bonding conductor?Whats to stop someone replacing a part of pipe a bond is on and not reattaching the bond??
RF wrote - Nothing, but I expect most people wouldn't as they realise it is forming part of a bonding arrangement. It's going to be entirely not obvious that a bit of pipe is.
Are you seriously suggesting a normal everyday person has any idea what a bonding arrangement is??
and as i said - As for the labelling that means nothing to a lot of people if they want to cut/remove etc etc they will regardless!! example on a much more dangerous scale the copper thieves stealing from sub stations etc!
Also the label is only at the end whats to say they wont cut it somewhere through its run as last time i looked earth wire does not conform with bs951.
And Vibro im not saying whats the point in bonding as the connection can be broken at all you said that.
Im merely stating that if someone wants to cut it they will same as everything one thing you can never predict is a human being and the stupidity of some if not all of us sometimes. As i said no one is perfect.
I have never once said this was acceptable i was making a suggestion infact more of a question i never once said i would install it in this manner i was making an observation/questioning my statement.
