Which are not met in this scenario!What is has proved is that BS7671 does not prohibit the use of a water pipe (extraneous conductive part) to be used as a bonding conductor providing certain criteria are met as RMS stated.
Just testing for continuity will not permit the use of this pipe. It fails to meet the criteria needed!My interpretation of this is that compliance can be achieved by confirming the integrity of the pipe work by means of testing.
So you are now admitting that the pipe can not be used as the criteria needed can not be met. At least you are big enough to admit that now!Well please can you point me in the direction of this reg because no one else can!! It says it is permitted providing certain criteria is met!!Fair enough in this case it is not i accept that.
Well given the posts from BAN and yourself I would positively say that BAN has far grater technical knowledge/experience than you. As you seem to relish how BAN was treated of this princeofdarkness then why are you kicking up fuss that you are being treated in the same manner?Except he had a far greater technical knowledge/experience than yourself and constantly reminded you of when you were severly lacking in knowledge and being put right.As well as consistently outdoing you with his remarks and put downs?
Well it seems that you do not appreciate the guidance that has been given to you in this instance do you. Instead of accepting that your idea was/is ridiculous and does not comply, you decide to try and find reasons to back track to make it sound as if it does given it meets the criteria that you had no previous knowledge of!Again i dont deny i need guidance on many things are you saying you dont ever??
starspark maybe we are being a bit unfair here as it seems that you may be new to the trade and we all need to start some where.
