Range Tribune (Pressure at 0 & Cold radiators No heating ) Urgent help requested please
Still like to know how the CH system water contents expansion is taken up, perhaps in the central plant room, IMG1736 does indicate a pressure of ~ 0.75bar?.
Im going to try top up the Expansion tank with pressure today. Got a mini car pump.
If your heating doesn't work, pester your landlord until they sort it out. It is their responsibility and part of what you pay all that rent for. They should also explain how to control the system and how to do basic maintenance like topping up system pressure if relevant.
Yes currently writing several complaints to the Housing Estate management and the landlords property management companys.
Don't do it . You have no business working on an unvented cylinders components. A plumber needs a G3 certification to be authorised to work on them. You have no idea what you are doing and it has nothing to do with the heating systems pressure.
Lesser men, have attempted greater feats. Is there a possibility it could explode? Looks **** easy on YouTube.
Don't touch the unvented cylinder components. As terryplumb says, you are not qualified to do it. Also, if you tamper with it, the landlord or their agents will likely then blame you for any problems they find and will send you a bill for repairs.
