Rcd twin switched sockets tripping house cu??
I'm not trying to be aggressive when I say this, but, if faced with a judge in a court of law, how would he see your interpretation of the wording?
I happen to agree with you whole-heartedly, but I don't feel that that is how the folks that wrote it intended it to be interpreted.
I'm not trying to be aggressive when I say this, but, if faced with a judge in a court of law, how would he see your interpretation of the wording? I happen to agree with you whole-heartedly, but I don't feel that that is how the folks that wrote it intended it to be interpreted.
I have responded to this in a new spin-off thread here . Would any folk wishing to continue this discussion please respond in the new thread. Thanks.
Kind Regards, John
Slightly back on topic...
I've decided to redo the electrics:
Swa in an galvanised adaptable box on back wall of house and terminated into a 13amp rcd plug in adapter.
Swa upto the shed and into a surface mounted twin switched metal clad socket where I'll run x2 more twin sockets in radial circuit. I'll use a 5amp switched fused spur for the lights (spurred off a socket) all run in conduit in shed 2.5mm t&e for sockets and 1.5mm t&e for lights.
I'll get a qualified sparky friend to pop round to sign it all off and check it all out.
So I power it up and all is ok but when I click the "test" button on any of the rcd sockets in the shed it trips out the house mcb (house has a split rcd cu).
If the test button on the sockets creates the testing un-balance with a resistor to ground than all RCDs along the route will see the same unbalance and trip
Have I gone over the top on rcds or am I missing something else?
yes and yes, you are missing the basic knowledge of how to design a safe electrical installation. So many RCDs will ( hopefully ) make the risk of electrocution acceptable low. BUT by mis use of RCDs you have added dangerous hazards to people in the house who may be plunged into sudden darkness due to a minor problem in the shed.
Wrong decision.
QED.
You obviously don't value his friendship, or you wouldn't ask him to lie for you on official documentation.
What I know as an adaptable box (folded up bit of galvanised steel) is far from waterproof and therefore unsuitable for outdoor use.
So still plug in (generally better hard wired), and still a superfluous RCD.
For the types of RCD under discussion, you cannot get discrimination between them - have a fault and it's almost certain that both (all) in the circuit will trip.
You would be far better taking the circuit back the CU and supplying it from it's own MCB in a non-RCD way. But really, for the reasons already given, you would be better getting someone qualified to do it for you - safely.
