These immersion boost affairs are the equivalent of a PWM lighting dimmer connected to the immersion heater. ... 230V AC input, output is a chopped sinewave.
Input current will follow the chopped AC output.
Indeed - as I've now discovered. I had previously thought that they might be a bit more clever than that, enabling solar power to be used for supplying an immersion in the absence of the grid supply - but seemingly not
Indded, and it's that last bit is what Irecently questioned (by implication). Although eric seems to feel the need for it, I'm not sure I would feel it necessary to have RCD protection of a circuit supplying only an immersion.
It's described as DC with PWM - but I now strongly suspect that,as flameport has suggested, it's probably just chopping the AC waveform- i.e. such that the magnitude of pulses varies during the (AC)_ cycle, as well as their width being 'modulated' to achieve control.
So you are just guessing too. The only person who can tell us for sure is Eric who can look at the output on a scope, but I suppose that won't happen either.
Yep, in the absence of more information, we can do nothing but 'guess' - but it can at least be an attempt at 'intelligent guessing'. I can't see why they would bother to rectify and smooth the AC and then chop it into pulses of roughly equal amplitude (which is about the only other sort of 'PWM' it could be), when it is simpler just to chop a full-wave-rectified waveform.
In any event, despite the guessing as to whether the pulses are of roughly equal amplitude or varying through each half-cycle, I don't think that makes a blind bit of difference to what we have been discussing, does it?
It looks like what we finally ended up with was somewhere between my guess and flameport's guess. The input *IS* rectified, but the DC is never smoothed and then the rectified output is PWM'd. It's unfortunate that the video author was unable to test it properly as he didn't have the sender, so we only got to see the waveform in "max power" and "off" modes.
.... I can't see why they would bother to rectify and smooth the AC and then chop it into pulses of roughly equal amplitude (which is about the only other sort of 'PWM' it could be), when it is simpler just to chop a full-wave-rectified waveform.
