Refurbishing my first house
You ripping that out and popping in a wood burner.
Yes, most likely it will need a new flue liner, at least the stack is solid. I´m on a smoke control zone, and fancy a double sided wood burner, have to measure and start looking around.
Out with the old soil stack:
Asbestos?
New steel ready to go in
The old beam was just bearing over 5 or 6 cm over a slice of a brick
Slowly separating it
Beam is out!
Doing the other side of the very bulky fireplace:
The timber beam is not bearing the joists for a few mm, the plasterboard ceiling and some brick slices are bearing the load on the other side:
