What I want to achieve is - with an OT enabled boiler and an OT enable smart control that the system can be set, through the programmer, that there will be 2 separate flow set temps depending on the call.What specifically do you want to know?
When the programmer calls for CH, it specifies 50deg flow temp, then when HW is called for it raises that flow temp to 60deg to the cylinder, with the HW set temp taking precedence if both are being called for.
I don't want to have to change the system to be a priority HW system, or have to change the boiler ideally if it's already OT enabled, I also want to keep the system as either an S Plan or Y plan.
