Hi, I work for a large electricity company. We have two to four injuries a year through pulling cutout fuses. All meter fitters are trained and required to use visor and gloves (although tbh they don't usually bother).
I've pulled a cutout a couple of times to do a CU replacement. Just be aware it's a real risk.
Sounds like the risk assessment isn't fully considering the risk. There's a case for some form of non-metallic clamping extension device to ensure the operator's hand is well removed from the potential danger.
In some cases, possibly. But in the general case I suspect a considered risk assessment would show risks added by using the device could be more than are saved. Wearing the correct PPE for the level of arc that is likely to occur - and as previously explained, the potential arc energy is a reasonably predictable quantity. The right gloves, long enough to give a good overlap with suitable long sleeves of a suitable fabric, will protect the hands and arm for long enough to make a quick exit. Similarly, the correct head and face protection will prevent serious injury to the head and face. Ditto suitable clothing to protect the torso and legs.
Apart from the gloves and face protection, the rest (if chosen properly) should be no more uncomfortable to wear than "normal" clothing. The hand and face protection is only needed for a fairly short time as MeterMan explained in post 39.
