Here they are then, the before and after photos:
I'll admit, there is still a little finishing up to do decoration wise!
The sparks from Western Power Distribution were fantastic. They were booked to replace the service fuse unit, but while they were there they moved it into the corner and moved the meter up the wall so it was out of the way. All for the price of a cup of tea. They didn't even want the biscuits I'd bought for their visit! I had already mounted the new consumer unit (with bottle tops
) and added the necessary bonding to water and gas pipes. They moved the meter and connected it up to the main switch inside the CU. Here's a photo:
The second photo shows the old fused switches, available to anyone who wants to do some work with that pre-2004 look. You know who you are, with your stock piles of red and black!
The DNO fitted an 80A fuse with 16mm tails throughout. A 100A fuse with 25mm tails would have cost money (for an assessment I assume), as would converting the TN-S to PME. The existing 2 circuits (lights and sockets) have been wired into the new CU while I fit the new circuits.
Eventually I'll have 9 circuits:
Upstairs, dowstairs and outside lights.
Upstairs, downstairs and kitchen mains rings.
Sockets in loft with lights on a fused spur.
Bathroom heater, Immersion heater.
This made a full set of RCBOs too expensive, so I'll have the lights on RCBOs and the other circuits on the RCD protected side of the split CU. There's still room for shower and cooker circuits, but I don't need them at the moment. Let me know if this doesn't sound sensible.
Why not get a spark in and do the lot for £300-£350 including parts?
How do you know that insulation of the cables are ok?
You're right - I won't be saving much money, but this way I get to have all the fun
I wasn't sure about the insultation either, so I'm installing new ring circuits with new cables. I'll also replace most of the lighting cables.
