Please show us where the law prevents you from making an electrical installation safer.Try reading Schedule 2B.My question is that since this CU is a replacement for an existing unit, and is fed via an MCB from the house's CU, does it really require notification?
You are proposing to change the device currently providing protection to the garage circuits for a different one. How on earth will the existing protection be unaffected?The circuit's existing protection would remain unaffected.
What about the temperature rating of what the cable is connected to or passes through?It is the XLPE type, so I have no worries about the house CU MCB rating,
Putting 'CU' in quotes like that won't make it less of a one.and I agree that the double socket, presumably with built-in RCD, is a sloppy way to go compared with a garage 'CU' containing separate MCBs for lighting and ring.
Well you are wrong. It just refers to a consumer unit.It is my belief that when Part P refers to a 'Consumer Unit', it is in fact referring to a unit connected directly to the meter, i.e providing primary protection to the garage circuit.
I agree, but that "sense" as you call it is actually a nonsensical invention of yours, so your argument collapses. It would be acting as a consumer unit because that's what it ******* well is.When connected via an MCB in the house CU, it would not in fact be acting as a 'Consumer Unit' in that sense.
Protection of what is unaffected? What is the house CU MCB protecting?Protection is unaffected as this is provided by the house CU's MCB.
It's gratifying to know that you have all the necessary test equipment which you will need to make sure that you are not in any way going to adversely affect the safety of the garage circuits.The important thing to note is that this is not in any way going to adversely affect the safety of the garage circuit. Quite the contrary in fact!The law really is an ass if it seeks to prevent people from adding safety!Indeed it is, and much of it calibrated by the NPL, not that such accuracy is required for house electrics!
This work does NOT change the device currently providing protection to the garage circuit. This is and will remain provided by the 32A MCB in the house CU. As far as the lighting circuit is concerned, that does not require
Remember that there is nothing stopping me from adding extra lighting or sockets, and I can add extra fuses as required for spurs etc. It makes no difference whether a 'fuse' is a wire device or an MCB.
Putting CU in quotes does make it 'less of one' for the reasons outlined. e.g. if I were to put in a tripple socket as a spur, I would add an in-line fuse if one is not incorporated in the sockets. However, I could install a suitable MCB in a box if I wanted to.
I think you need to look at the definition of a 'Consumer Unit'. A box with two fuses and a switch does not a consumer unit make! It's only a consumer unit when used as one.
As it doesn't disallow anything it's hard to see how that can be, but feel free to show us where you think it does.[/quote]It allows other work that is potentially more dangerous for pity's sake!
Wow! That's a lot of questions! Here goes...
1. I read it - still not convinced. Semantics and all that.
2. No. See 7 for more.
3. Good point. I'll look into the temperature rating issue. If it's a problem, I'll use a lower rated MCB as I don't need 32A.
4. When is a CU not a CU? When it's a Switched FCU of course!
I can't use a switched FCU as a CU because it has not been designed for the job, probably won't accept meter tails and besides, wire fuses are no longer acceptable for the job, but I can use a CU as an SFCU, because that’s effectively what it is!
5. See 4.
6 . See 4, and please don't swear.
7. The house CU MCB is protecting the SWA to the garage, and would be adequate for the whole circuit if the SWA simply connected to a standard ring. Of course, there is the lighting circuit, but that could be wired via a 5A FCU. In fact it is, albeit a rusty one!
8. If the law makes it unduly expensive or inconvenient for someone to add a safety device, i.e. makes them pay for a registered electrician to do a job they can safely do themselves, or makes them go through all the rigmarole and expense of getting PD inspectors in, they either won't do it or they will ignore the rules.
Is there any evidence that Part P works? I understand that the death rate went up after it came into force!
Can we please keep the size of posts down? I really don't fancy responding to this if it comes back at me broken down into forty bullet points!
