dvd freak said:
both PC's have 500 watt supplies in them and with both running together 1000 watts could be consumed if maxed out.
That's only a little over 4A though. Even when you add in monitors, printer(s), scanner(s), speakers etc etc, it'll probably all run off 1 13A socket...
there are 3 slots on the buzzbar
Your busbar shouldn't buzz - if it does there's something wrong...
she wants 3 double sockets as opposed to the 2 that already reside there so another one adding will do the trick.
IIWY I'd consider putting in 6, or 8 or more sockets - can never have too many in a kitchen, all on their own ring, plus possible extra provision for WM/DW/TD...
There is only 1 32a MCB that connects the shower so I would need another to feed the double electric oven on it's own circuit.
Take the opportunity to upgrade the shower circuit to 45/50A, 10mm², and lay in a cooker circuit which could handle an electric hob as well, if required.
Also I would like to have a seperate circuit in the loft just in case a socket trips out downstairs, I will not lose data or damage my hard drives. I was thinking of replacing my CU with a newer version that has around 10 MCB's in it
10 is a bit low, you'll probably find, when you start planning things more closely - 1 or two rings for the kitchen, a non-RCD supply for the fridge/freezer, 3 rings for downstairs/upstairs/loft, oven & shower, and that's eight gone already. Then there are lights, outside (shed/garage/garden), possibly alarm(s), and a couple of spares on each side (RCD/non-RCD)...
Also, do you know what sort of supply you have? If it's a TT earthing arrangement then you'll either need to get that changed, or install the appropriate 100mA-Type-S/30mA split-load board.
but although I have no problem re-wiring the new one in I do have a problem doing this live! I noticed that there is no master switch below/attached to the meter
You could install one of those, too...
but below the meter there is a box that is fastened with wire, I take it that there is a master fuse in there.
If you mean before the meter, and separate from it, just where the service cable comes in, yes.
Would it be wrong of me to remove this fuse whilst I replace the new CU?
Wrong as in not allowed, yes.
Wrong as in not doing it and working live, very much no.
I notice that there is a warning saying that it should not be tampered with but being on a budget I do not want someone doing what I can do myself and charging me for it (don't get me wrong I would pay if I had to).
I have had a few people tell me it's ok so long as I do the job properly on the other hand I am a little skeptical regarding the legal (if any) implications.
It is technically illegal for you to tamper with the fuse, but nobody has ever heard of someone being done for it, unless they've decided, whilst the fuse was out, to connect some of their stuff up to before the meter.
Any advice would be gratefully appreciated
The standard advice is "do not pull the fuse", followed by "but if you do, then do it safely". If you search this forum you'll find lots of tips.
But before you do that, have you approached your DNO? Some are much more cooperative than others and will for free, or for not much money, come and fit an isolator for you. If you tell us where you are, someone might be able to say how friendly your DNO is.
