I am contemplating replacing an off peak storage heater which was removed a couple of years ago.I understand that there was nothing wrong with it, but it didn't fit in with the room decorations !
I believe this was 2.5 kw capacity. I am looking for a replacement of 3.4 kw if convenient.
The original wiring is still in place from the separate off peak circuit which curredntly feeds other OP heaters, water heater, etc.in the house.
The switcht was replaced with a white blanking plate, so replacing it should be no problem
Should I connect the new heater with a FUSED on/off front entry switch ?
If so, what capacity heatproof cable and fuse, should I use for a) a 2.5 kw heater, or b) a 3.4 kw one
Or is a FUSED switch necessary ? All other heaters in the house are fused.
Your advice will be appreciated.
