Restoring Off Peak heater
15 Nov 2011
West Midlands
I am contemplating replacing an off peak storage heater which was removed a couple of years ago.I understand that there was nothing wrong with it, but it didn't fit in with the room decorations !
I believe this was 2.5 kw capacity. I am looking for a replacement of 3.4 kw if convenient.
The original wiring is still in place from the separate off peak circuit which curredntly feeds other OP heaters, water heater, etc.in the house.
The switcht was replaced with a white blanking plate, so replacing it should be no problem
Should I connect the new heater with a FUSED on/off front entry switch ?
If so, what capacity heatproof cable and fuse, should I use for a) a 2.5 kw heater, or b) a 3.4 kw one
Or is a FUSED switch necessary ? All other heaters in the house are fused.
Your advice will be appreciated.
If the circuit is still connected at the other end and assuming it is still in good condition and complies with regs
No, at 14A-15A (for 3.4kW) load a 13A SFCU would not be adequate.
1.5mm2 for the cable
As long as there is adequate protection in the consumer unit for the cable then additional fuses are not necessary. If there is adequate protection then a 20A double pole switch would be better.
Thanks for your advice.
>>>1.5mm2 for the cable <<<
This is for a 2.5 kw heater ?
What will I need for 3.4 kw heater (to connect from heater to wall switch 20a DP) ?
RLux[/code]
If the OP is not making any mods other than re-fitting a new heater and outlet which was originally fitted, why would the circuit have to comply with the new regs???
Many thanks to all for help and encouragement. An excellent Forum.
(Not qualified to answer that last question I'm afraid !)
RLux
