Is this the typical unhelpful response from a "competent engineer" or don't you know the probable cause of the problem. Either way, it does not help me as I have the same problem (without the swimming pool )Anyone with their own swimming pool can afford to pay to get this fixed by a competent service engineer .
Thanks for your interestfire away dear boy whats your problem
could be your drive coupling is broke between your pump and motor, you would have to connect an oil pressure gauge to your pump and when the motor spins crack open the bleed screw and see if the oil horses out. If not its your drive coupling is broken.
first thing i would check is the photocell and solenoid coil have not gone open circuit both easily checked with a multimeter
Peasant why the hell have you responded to a dead thread?
Any Decent Engineer that knows Riello Burners will be screaming PHOTOCELL its the sort of fault that you can diagnose without even seeing the job, This is what happens when Gas Engineers pretend to know all about oil. Oil & Gas while they have common ground, are very different due to the very different way in which the different fuels are presented to the combustion chamber.
Try your photocell,next time fan runs but it wont ignite,disconnect it,if its at fault burner will ignite then go out after a few seconds.
Glasgowgasits a dead thread i know but...............
Peasant, i will bet a cyber pint its your photocell (magic eye in your parlance).
ringy1Would I be getting 5bar if the coupling was broken? no you would not even get any pressure on your gauge with a riello with the solenoid coil not opening and 5bar pressure is far too low for a burner to fire
