So, notionally your rafters are balanced at an angle on the new dwarf walls and cantilever out to the ridge, span down to the walls. If the span from ridge to dwarf wall is shorter than from dwarf wall to house walls then it's likely stable enough with the self weight of the roof but if they sag over time, either side of the dwarf wall you may well see some spread and rotation of the dwarfs. Interesting design but if an SE's signed off on it then no problems!
How did you fix the wall ends of the rafters?
