WarmSoks said:] wonder what regulations it will have to go through before it can be used in the UK
If it really does what it says on the tin, you'll need a license from the Nuclear Installations Inspectorate and you'll have to comply with the Ionizing Radiation Regulations.
You'll be required to build a suitable enclosure for it with adequate radiation shielding. You'll also have to do regular radiation surveys - which the HSE will check - and carry a personal dosemeter if you want to go in and service it, even if it's switched off. What am I saying? You'll have to fit a safety interlock to the door so that you can't go in unless it IS switched off!
But of course it's all a scam anyway.
Edit: maybe "scam" is too strong as it implies a deliberate attempt to defraud. Make that "cock-up".
Additional edit:
I said:-- if you want to go in and service it --
On second thoughts, you won't be allowed to go anywhere near it. You'll have to get an RNI in - and it'll be no use looking for help on DIYnot because the Nuclear forum will be restricted.
