I think we have to take heed that there can be sometimes be confusion over the word "point", it actually means a "point of utilisation" such as a socket (a single, twin, triple etc socket is1 point of utilisation).
Indeed. In fact, in present context, I think the word "point" is worse than just 'confusing' since, I genuinely don't understand what (in relation to situations we're talking about) it is intended to mean in 522.6.202.
As I've said, if taken literally a point has no dimensions (is infinitely small) and therefore would create zones (in which one was permitted to bury cables) which were infinitely narrow. ... and it's not really as simple as you suggest above, because a socket (and other things) is already considered by the reg as an "accessory", so "point" is not relevant for such items.
This is very relevant to this discussion, since the sort of large items we're talking about (mirrors. TVs, boilers etc.) are certainly not (electrical) "accessories" or "switchgear", so if they are covered by 522.6.202,it can only be as "points"
As with "safe zones" well you runs cables in those zones in the futile hope that the person with the drill looks at it and thinks "Hah , no I will not risk drilling there!"
Indeed - but, as I've repeatedly said, and as I'm sure you understand, I have
not been asking about the situation from that person's; point of view - I have merely asked for views as to where BS7671
permits cables to be buried (<50mm deep) in relation to large piece of current-using equipment attached to a wall - and no-one has really yet given me much of an answer to that question.
As for the 'man with a drill', the "safe zones" would cease to have much useful meaning if (per my silly diagram in post #26) that zone covered a large proportion of the wall. If the person had to drill a hole in the wall, he/she would therefore have to use some other method (other than guidance based on 'safe zones') to determine where cables were (or might be
No they still conspire to drill the hole or hammer a nail in to hang that picture on the wall.
Indeed. I can tell a story about my own stupidity .... a few decades ago I had a floorboard up for some reason, and there were a pair of copper CH pipes going along its length, in notches in the middle of the top of the joists. Having completed whatever I was doing, I replaced the floorboard and religiously/carefully secured it with nails which I made sure were well away from the centre of the board (hence pipes).
When I had put in all those nails 'near the edges of the board', I found that it was 'wobbling' a bit at one end. In some sort of auto-pilot mode, and clearly without much thought, I therefore took a nice long nail and a heavy hammer and hammered the nail in right in the middle of the wobbly end of the board ... the rest of the story does not need to be described
I have also, just once I think, drilled through a live electrical cable,but I really don't think I can be blamed for it. There were absolutely no electrical accessories (nor 'points' or switchgear!) anywhere on the wall I was drilling into, but it transpired that there was a cable buried in the entire height of the wall, being a feed for a lighting circuit from below the floor to above the ceiling!
Kind Regards, John
