May I be excused for saying "Arrggghhh !!" ?John, I think that, inevitably, it means that they may be buried anywhere in said zones and should always be treated as if they might actually be anywhere in said zones unless we have conclusive proof that it is buried in more restricted bands within such zones.
I totally agree with what you say, but it still leaves the (my original) question as to what are the "said zones" in the case of a large item of current-using equipment fixed to the wall - in other words, where does BS7671 permit cables to be buried in such a situation?
Are you saying that you believe that it is permitted to bury cables anywhere in the zones I indicated in my ('silly') diagram in post #26 ? If so, that would very simply answer the simple question I asked in my OP nearly 5 pages ago, although I'm not sure that I (or others) would regard that situation as sensible (my #26 diagram has already been 'ridiculed', with more than a little reason!).
National would do me, not necessarily international However, as I'm sure you understand, I was simply offering a suggestion as to how the regs could address (could have addressed) this issue had they wished to, with no expectations that such will necessarily ever happen.Ideally, an international law making all items connections within say 100mm of the centre or within 100mm of the top right of the item in in its normal intended mounting orientation or some alternative convention might be helpful but will never exist.
It does rather sound as if you agree with my #26 diagram as indicating what would (per BS7671) be 'permitted routes' for buried cables (probably even the 'diagonal' ones). Is that the case?So , anywhere they might be is the answer, even if it includes almost the whole wall. ... Its not what we like but it is what we have.
Kind Regards, John
