Less than 5 volts because the voltage is the difference between the potential on the neutral bar and the potential on the neutral block in the cut out where the CPC is jointed the the neutral. This is a very short and very low impedence length of circuit, typically less than 0.1 ohms, so with 50 amps flowing through it the potential developed between those points is typically less than 5 volts ( 50 A x 0.1 ohms ).
Ah I see, you meant specifically a TN-C-S system? Yes I would agree with that.
thank you
