Several sockets and lights on a spur?
24 Nov 2013
Berkshire
Hello All
2.5mm ring is protected by a 32a rcbo in the main consumer unit.
I'm thinking about using a short length of 4mm to spur from a socket into the garage which is on the other side of the wall. This would feed a small "garage" consumer unit with a (I think pointless from a protection point of view) 40a or 63a main breaker switch. From there would be a single 2.5mm radial on a 16a mcb and another 1.5mm radial lighting on a 6a mcb.
Is that allowed or does the whole lot need to be on a 13a fused spur or does it all need to come direct from the main consumer unit ?
Electrically and regs wise there is nothing to stop you putting a consumer unit on a ring, it does offer an advantage of total isolation of the garage if required. I would suggest using nothing bigger than 16A MCB's or RCBO's.
It would be nicerer to extend the ring to the new CU with 2 cables to match the existing ring rather than use a 4mm² spur.
