Isn't the only advantage of open-vented that the radiator circuit pressure will be lower, so is less likely to leak immediately if it's on its last legs? Otherwise, if the pipes and radiators are in OK condition, why would anybody want to stay open-vented?
Why take a chance?
Such a system is bound to weep after it is cleaned when under pressure
If the pipework is corrected to conform with OV setup, do not see any issues.
Have fitted suitable combis to what was open vented, retained as open vented.
Do I want to be constantly running back to address the problem of dealing with micro leaks on system where I have converted to sealed system? Not if I can help it.
If present system is sealed, no problem, will keep it like that.
Can immediately recall two open vented systems easily 35 plus years old now have a combi working as open vented- zero issues.
